Retired_Member's avatar
Retired_Member
Jul 31, 2022
Cannot check firmware updates
Im trying to check A7000 firmware updates with genie software, it advances to 20%, and stays there forever ?
  • Retired_Member's avatar
    Retired_Member
    Jul 31, 2022
    But you didnt understand that i have been doing what you suggested in first place ?
    Anyways, if this usb stick is allready abandoned by netgear, i wont bother anymore 🙂
    Ty you for the suggestions and for replying.
