NetRags's avatar
NetRags
Tutor
Oct 24, 2015
Cannot connect NETGEAR wireless USB adapters to Windows8, 8.1 & 10. Error: "Limited Connectivity"
Hi Team,
After installing the NETGEAR wireless USB adapters in the Windows8, 8.1 & 10 getting a message "Limited Connectivity"
TSH done so far..
#1. Uninstalled the existing driver and updated the latest driver
#2. Restarted PC
#3. Tried with different wireless channels and security settings
Still getting the same message, unable to connect. Not getting IP too.
Thanks,
NetRags
1 Reply
  • Hi NetRags,
    Welcome to Community!
    If you have any antivirus or firewall enabled, try disabling it for the mean time while installing the NETGEAR adapter. May I know what is the model number of your adapter?
    JamesGL
    Community Team
