RandalV
Feb 20, 2016Follower
Netgear A6210 Windows 10 5 GHZ problems
Dear people,
I've been having real headaches finding out what the problem is, but my Netgear A6210 simply won't find 5 GHz networks.
I work at my ISP, so I've tried changing every setting I could possibly think of and scanned all over with inSSIDer and netscan but no 5 GHz channels found.
If I plug in the stick I use at work (TP-Link Archer T4U) it instantly works.
I use all this in combination with a USB 3.0 port, and windows 10. Anyone can help me here?
Kind regards!
Randal
1 Reply
- JamesGLNETGEAR Employee Retired
Hi RandalV,
Please check the properties of A6210 under device manager. Check the channel mode, make sure it is on "both" and not 2.4Ghz only.
