LeoPalmer's avatar
LeoPalmer
Follower
May 01, 2016
Netgear N150 wireless USB Adapter keeps turning itself off after Windows 10 upgrade.
Since an upgrade to W10 my N150 wireless USB adapter keeps turning itself off. I have the latest Netgear drivers installed. It will work for a short time after unplugging and re-inserting then it goes off.
I have two identical systems the other one works perfectly. I have swapped the adapters but the fault remains the same, the other machine works perfectly with both adapters.
I have run out of ideas....can anyone help please.
Thanks
Leo
1 Reply
  • You can try disabling any power management for the adapter.  There are two settings I am aware of.
    1. Under the advanced settings in the Power Options Control Panel, you may have an option to adjust the Wireless Adapter Power Saving Mode.  I have it set to Maximum Performance on my Windows machines.
    2. In the Network Adapter properties for your wireless adapter, you may have a Power Management tab.  If you do, then you can uncheck the option to allow the computer to turn off the device to save power.
