n4hmrhamm's avatar
n4hmrhamm
Follower
Jan 29, 2023
WNDA4100 Genie program quit loading in Win 10
I am using the WNDA4100 adapter in Win 10, and it is working properly (as best I can tell).  After the original install of the adapter and Genie, Genie would load fine but now it will not load.  When I try to start Genie I see a quick flash on the screen which then disappears -  won't load.  Won't load from the exe file either.  Note: Win 10 is fully updated.as well as Norton 360, etc.
The Genie File Version is 1.2.0.10 and the Product Version is 1.2.0.14.
How can I fix this?
1 Reply
  • plemans's avatar
    You don't need to use genie. Windows own built in wifi manager works fine.
    Just uninstall the genie/driver/utility and install the stand alone driver. then let windows manage the adapter.
