jmrichmond's avatar
jmrichmond
Follower
Nov 05, 2021
GS116v2 and IEEE 802.3ad
I have an old 16 port net gear GS116vs ethernet switch that is several years old.  My question; does it support the Link  Aggregation Group protcol, IEEE 802.3ad ??  Thanks in advance for your help.
Model: GS116v2|16-port Gigabit Switch 10/100/1000 Mbps
  • Peggy75 wrote:
    C1-C16 is a Netgear GS116v2 smart managed switch
    No idea what C1-C16 means in this context - this would be a GS116E or GS116Ev2.
    According to the fine  Gigabit Ethernet Smart Managed Plus Switches User Manual p.51 ff.
    Set Up Link Aggregation Groups
    Note: Static link aggregation (port trunking) is supported on models GS116E, JGS516PE, JGS524E, and JGS524PE
    Note: The switch does not support IEEE 802.3ad Link Aggregation or Link Aggregation Control Protocol (LACP) groups but supports manual static LAGs only.
    Peggy75 wrote:
    ... switch is Balance XOR (IEEE 802.3ad draft v1), this is sometimes called Round-Robin.
    Yes, this is one of the modes to be used on a host for a static LAG.
    https://www.downloads.netgear.com/files/GDC/GS105EV2/WebManagedSwitches_UM_EN.pdf
  • schumaku's avatar
    schumaku
    Of course not - because 802.3ad (dynamic LACP LAG) requires at least some configuration controls.
  • C1-C16 is a Netgear GS116v2 smart managed switch ... switch is Balance XOR (IEEE 802.3ad draft v1), this is sometimes called Round-Robin.
    • Peggy75's avatar
      Peggy75
      Oh so sorry but i am not sure about that... Thanks !!
    • schumaku's avatar
      schumaku
ProSupport for Business
