dfp
Aug 14, 2013Aspirant
2100 Expansion Problem 4tb drives x 4
I have a Readynas 2100 with 4x 2tb drives.
I have replaced these drives one by one with 4tb drives so I now have 4x4tb drives.
I didn't run the expansion until the end, when I rebooted the NAS.
Now I have a 10tb volume. From my calculations with x-raid2 this should be around the 12tb area?.
Any advise on what is going on would be great :)
- mdgm-ntgrNETGEAR Employee Retired0.9*12=10.8 which rounded down is 10.
Remember disk manufacturers use 1KB = 1000 Bytes whereas the NAS considers 1KB = 1024 Bytes. - dfpAspirantThanks, yes that makes sense!
- mdgm-ntgrNETGEAR Employee RetiredBtw what version of RAIDiator are you running?
- dfpAspirantRAIDiator 4.2.24
Which I think is the latest currently. - mdgm-ntgrNETGEAR Employee RetiredYes. Was just checking to make sure that is what you are running.
- jdgsAspirantCan you confirm that 4TB drives are quite happy in the ReadyNAS 2100? Which model drives did you use? I currently have 2TB drives, and am running out of space, but was reluctant to upgrade to 4TB drives due to them not being on the compatibility list - the largest being 3TB.
- mdgm-ntgrNETGEAR Employee RetiredThey should work but if you run into issues using disks outside the compatibility list support will be unable to help.
Not all drives are equal. Some are more suited to NAS use than others.
