BadBrad's avatar
BadBrad
Adequate RAM? (How to determine)
I have a Readynas Duo v1. I am interested in putting on a couple more add-ons above what I have already put on. In particular the own cloud 4.0.7 add-onwhich requires the PHP 5.3 add-on. I am running the latest firmware for the Duo v1 and I use the twonky-media 6.0.38 and the Rsnapshot add-ons.
Given that the Duo v1 has 256MB of RAM I am wondering if it is adequate for running the owncloud and php add-ons in addition to the other ones I put on.
Is there a way to tell what memory usage each add-on takes?
What are the consequences with the add-ons using too much memory?
Is there a tool (I have command line access via SSH) I can use to see current memory allocation?
Any other recommendations for proper stream-lining of memory usage on the Duo v1?
Thanks,
Brad
1 Reply
  • After logging in with SSH, you can use the 'top' command to view memory usage and CPU load:
    top - 14:45:28 up 17 days,  2:53,  1 user,  load average: 0.00, 0.04, 0.05
    Tasks: 110 total, 1 running, 109 sleeping, 0 stopped, 0 zombie
    Cpu(s): 0.2%us, 0.3%sy, 0.0%ni, 99.5%id, 0.0%wa, 0.0%hi, 0.0%si, 0.0%st
    Mem: 1021844k total, 907828k used, 114016k free, 60760k buffers
    Swap: 524272k total, 396732k used, 127540k free, 143980k cached
    PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
    3744 root 20 0 28260 1684 1308 S 1 0.2 169:25.00 leafp2p
    1 root 20 0 2068 24 8 S 0 0.0 0:10.02 init
    2 root 20 0 0 0 0 S 0 0.0 0:00.00 kthreadd
    3 root 20 0 0 0 0 S 0 0.0 0:05.06 ksoftirqd/0
    6 root RT 0 0 0 0 S 0 0.0 0:00.00 migration/0
    7 root RT 0 0 0 0 S 0 0.0 0:00.00 migration/1
    8 root 20 0 0 0 0 S 0 0.0 0:00.00 kworker/1:0
    9 root 20 0 0 0 0 S 0 0.0 0:05.72 ksoftirqd/1
    10 root 20 0 0 0 0 S 0 0.0 2:16.09 kworker/0:1
    11 root 0 -20 0 0 0 S 0 0.0 0:00.00 khelper
    149 root 20 0 0 0 0 S 0 0.0 0:01.51 sync_supers
    151 root 20 0 0 0 0 S 0 0.0 0:00.05 bdi-default
    153 root 0 -20 0 0 0 S 0 0.0 0:00.00 kblockd
    154 root 0 -20 0 0 0 S 0 0.0 0:00.00 kacpid
    155 root 0 -20 0 0 0 S 0 0.0 0:00.00 kacpi_notify
    156 root 0 -20 0 0 0 S 0 0.0 0:00.00 kacpi_hotplug
    263 root 20 0 0 0 0 S 0 0.0 0:00.00 khubd
    You can also use the 'ps' (process status): http://ss64.com/bash/ps.html
ProSupport for Business
