cs_giuseppe
Apr 19, 2017Apprentice
BTRFS error (device md127): parent transid verify failed on
Hi,
I have a 316 upgraded to 6.7.0.
Last week balance started and after some days the nas stopped working so I must poweroff, next reboot the gui was unresponsive so I tried the 6.7.1 beta.
The fw install correctly but the nas was slow in the boot process, now after a normal boot I found many errors in dmesg:
"BTRFS error (device md127): parent transid verify failed on 12569160548352 wanted 13275 found 13479" and so on
There is a cpommand line tool to make a check/repair of btrfs?
This is a backup na sonly with dr-share so at least I can factory reset it, but if there is a tool for check/repair btrfs I think is the best solution
Thanks, Giuseppe
- mdgm-ntgrNETGEAR Employee Retired
Sounds like factory reset (wipes all data, settings, everything) and fresh backups would be the best way forward.
Any recent SMART errors on your disks?
- cs_giuseppeApprentice
Hi mdgm,
all disk are ok, no smart errors.
I think it was caused by the poweroff, I think some part of btrfs are damaged or not in sync.
Giuseppe
