Retired_Member
Oct 28, 2017Bad Ethernet Port READYNAS 516
Hi All,
I upgraded to release 6.9.0 and started getting the following message from my ReadyNAS 516.
"Bond interface bond0 has slave interface eth0 offline."
I went to look at the NAS (RN51600-100NAS) and sure enough the LINK lights are going off and on (on both the NAS & switch). The message is legit that the link is going up and down. I tried the following with no sucess:
* Swap to a different port on switch (Dell 2448)
* Change the actual cable
* Switch the cables eth0 and eth1
* Reboot
Go back and look at my device logs off my network management tools (Ubiquiti and FingBox) and this has been happening for a long time so 6.9.0 just exposed the isssue.
Any thoughts?
- SandsharkSensei
There have been many reports of problems with the network interface on OS6.9.0, and I believe yours is related to that. It seems like a diver problem which can cause the ethernet subsystem to reset periodically. I would hold off on condemning the hardware just yet,
- Retired_Member
Sandshark wrote:There have been many reports of problems with the network interface on OS6.9.0, and I believe yours is related to that. It seems like a diver problem which can cause the ethernet subsystem to reset periodically. I would hold off on condemning the hardware just yet,
So I think you nailed it, this morning both my ReadyNAS 212 and 516 were messed up. The 212 now reports having a bad port eth0 and now my 516 doing a resync. This release 6.9.0 was not ready for primetime. I think I may need to downgrade to protect myself....I guess I have learned my lesson. Don't trust Netgear to do QA.
Thanks Sandshark!
- TinyhornsApprentice
Yea, I have trouble with LACP as well, running 6.9.0.
There are alot of posts regarding it, and I have a ticket open with support regarding this as well.// T
