bsu74
Sep 06, 2012Aspirant
Disappearing Squeezecentre
I have a ReadyNAS Duo and when I tried to use my Squeezebox yo access my media it said I needed to update the Squeezecentre on the NAS.
I updated Raidar to 4.1.9 and also installed the Squeezebox Server through the System/Update controls. However when I go to the Services/Streaming Services all that shows up is the iTunes Streaming Server as not enabled and the ReadyDLNA as enabled. The only place I find any Logitech is in Services/Installed Add-ons where it shows the Logitech Media Server.
I could not get CleanSqueezeCenter to run and posts on a wiki and elsewhere say that it is not supproted now on ReadyNAS Duo.
Can anyone suggest what I am doing wrong?
- onimodAspirantThe current version of Logitech Media Centre ("LMS" - formerly "Squeezecentre") is available here:
http://www.mysqueezebox.com/download
Have a read of this thread for a bit more explanation:
viewtopic.php?f=22&t=61772&p=352961&hilit=lms#p352961 - bsu74AspirantI did what youj suggested and yet again I have LMS in the Installed Add-ons yet there is no Squeezecentre showing up in the Streaming Services. With no streaming service I can not run set up to allow the Squeezebox to access the media files on the ReadyNAS Duo. So thank you for the information but it hasn't resolved my problem.
- vandermerweMasterI assume you have a Duo v1.
Look at this thread. It should sort you out.
If it doesn't then there must be something else wrong with your Squeezebox setup. - onimodAspirantIt doesn't appear in streaming services any more (by design); only in Add-ons as you have noted.
Try accessing the setting page with a web browser?
http://wiki.slimdevices.com/index.php/Beginners_Guide_Overview:You can control Squeezebox Server from any computer on your network by pointing its browser at http://serverhostname:9000 (substitute your own Squeezebox Server's hostname!).
- nickslater63AspirantI have a similar problem
I am using LMS7.7.2 on a NAS Duo & could play music on several Squeezebox players & a Marantz NA7004
Following the Radiator update to 4.1.9, I can no longer see either the NAS drive or LMS on the Marantz.
Can still use the Squeeze players & can access LMS through the NAS as an installed add-on
Advice anyone? - vandermerweMasterLMS should be accessible in exactly the same way as squeezecenter streaming service was. You do not need a streaming service with LMS installed. I think it is likely that the problem you both have is with device network settings or LMS setup
Address :
Ipaddressofduo:9000
Have you both gone through the LMS setup on the NAS and rechecked your network settings on your devices? - bsu74AspirantThank you all for your help, I now have access to my music :D
