GammelGreggan
Oct 06, 2011Aspirant
How to install midnight commander on DUO
Anyone knowing how to install midnight commander on DUO?
- sphardy1ApprenticeNeeds to be installed & run from the SSH commandline:
apt-get install mc
- GammelGregganAspirantOk, thanks.
I am a newbie on Linux.
I will try this (and ask Linux-collegues if needed). - GammelGregganAspirantBy the way, is screen installed on DUO?
- sphardy1ApprenticeIf not, you can install it the same way
- GammelGregganAspirantThanks again
- GammelGregganAspirantI tried apt-get on DUO but got "-bash: apt-get: command not found".
- sphardy1ApprenticeSorry - the Duo doesn't come with apt pre-installed like the newer devices: http://www.readynas.com/?p=4216
- GammelGregganAspirantI installed APT but when doing apt-get it says it can't find mc.
- sphardy1ApprenticeDid you run "apt-get update" first?
- GammelGregganAspirantDid that now, worked better.
But getting "unmet dependecies". Want's me to run "apt-get -f install" with no packeges.
