Sandshark
Jun 21, 2020Sensei - Experienced User
Kernel headers unavailable for app build (linux-4.4.190-x86_64)
I've been messing around with the ReadyNAS OS6 virtual machine and wanted to see if I could make it recognize a USB device (mainly for encrypted volume recovery). That requires compiling and installing the VBox guest additions. So, I followed the normal process for doing that on a headless Debian system, and got an error when apt-get tried to install the kernel headers: I found this post Linux-Headers in the forum and did what WhoCares_ suggested. But when I executed make clean && make && make install && make modules_install, I got this:
HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/conf.o HOSTCC scripts/kconfig/zconf.tab.o HOSTLD scripts/kconfig/conf scripts/kconfig/conf --silentoldconfig Kconfig *** *** Configuration file ".config" not found! *** *** Please run some configurator (e.g. "make oldconfig" or *** "make menuconfig" or "make xconfig"). *** scripts/kconfig/Makefile:37: recipe for target 'silentoldconfig' failed make[2]: *** [silentoldconfig] Error 1 Makefile:540: recipe for target 'silentoldconfig' failed make[1]: *** [silentoldconfig] Error 2 SYSTBL arch/x86/entry/syscalls/../../include/generated/asm/syscalls_32.h SYSHDR arch/x86/entry/syscalls/../../include/generated/uapi/asm/unistd_32.h SYSHDR arch/x86/entry/syscalls/../../include/generated/uapi/asm/unistd_64.h SYSHDR arch/x86/entry/syscalls/../../include/generated/uapi/asm/unistd_x32.h HOSTCC arch/x86/tools/relocs_32.o HOSTCC arch/x86/tools/relocs_64.o HOSTCC arch/x86/tools/relocs_common.o HOSTLD arch/x86/tools/relocs make: *** No rule to make target 'include/config/auto.conf', needed by 'include/config/kernel.release'. Stop.
I tried to install the guest additions anyway, in case enough worked, and got this (in addition to some things that did seem to work):
VirtualBox Guest Additions: Kernel headers not found for target kernel 4.4.190.x86_64.1. Please install them and execute /sbin/rcvboxadd setup modprobe vboxguest failed
So, no dice. I'm no Linux programmer, but it appears clear to me that something is missing or misconfigured in the linux-4.4.190-x86_64 directory of ReadyNASOS_V6.10.3_WW_src.zip. And from what I've read here, it's a regular occurrance that something is wrong or missing whenever an OS update occurs. I guess it's no wonder hardly anybody even tries to develop apps for the ReadyNAS any longer when Netgear doesn't provide the proper (and as I understand it required by the GPL license) sources.
I guess I should also wonder why, apt-get install linux-headers-generic linux-headers-$(uname -r) does not work and the whole kernel build is necessary at all. That command gives me this:
Reading package lists... Done Building dependency tree Reading state information... Done Package linux-headers-generic is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source E: Package 'linux-headers-generic' has no installation candidate E: Unable to locate package linux-headers-4.4.190.x86_64.1 E: Couldn't find any package by glob 'linux-headers-4.4.190.x86_64.1' E: Couldn't find any package by regex 'linux-headers-4.4.190.x86_64.1'
- cleveland_rocksAspirant
Agreed. It would be nice to see Netgear address this issue. Maybe if more people comment on this we might get a response.
