MTUser2013's avatar
Mar 10, 2018
Many Duplicates for shared resource shown on player devices
I store copies of the DVDs that I own my NAS in the Media folder. On some playing devices, I see many copies of the same file. When I look at the folder on my Mac or Windows machines, I only find one copy of the file. If I delete from the Media folder, the player shows one less copy but all the other icons for the file are still there. If I click on play when I've deleted the file, the player tries to play all the versions of the file it sees, then plays the next video in alphabetical series. If I add back the file to the ReadyNAS media folder, I just get one more file icon in the folder.
This strange icon duplication problem is driving me crazy. I hope someone has had this same problem and knows how to fix it!
  • StephenB's avatar
    Mar 14, 2018
    Go into the web ui (system->settings->services).  Select ReadyDLNA, and click the Rescan button.  After the Rescan completes, the duplicates should disappear.
    Please do post back, and let us know if the rescan takes care of it.
    • MTUser2013's avatar
      MTUser2013
      Tutor
      Thanks for the reply. Yes, I think the duplicates show up on DLNA devices. I am using a LG Blueray Network Player, BPM35. Are these duplicates some kind of cache from the player? Can you get rid of them?
      • StephenB's avatar
ProSupport for Business
