grooovy
Mar 08, 2012Aspirant
NV+ V2 + DLNA + Toshiba 32SL800 = ZERO
Hi all!
Just bought NV+ v2 updated firmware to the 5.3.3. Installed the latest ReadyDLNA add-on.
I cannot see any images, play any mp3 files - they are not visible. I can see the sub folders where I put the files, I can see the files via BROWSE menu in web admin
https://192.168.1.XXX/admin/index.html but there are two problems:
- I can see video files on my TV but unable to play any. The length is being displayed as 00:00:00 and when I click play i see error "Media is not supported" (the same file shared via Windows Media Player is playing as it should)
- I cannot see jpegs and mp3 at all. Tried refresh DLNA add-on and it did not help.
I did system reset with wiping all data, but it did not help.
Any ideas what is wrong?
Or I have just bought a piece og cr..p which states that it is DLNA CERTIFIED? Is this some kind og joke, NETGEAR?
Please, anyone help me with setting up DLNA.
THANK YOU!
Alex
THANK YOU!
Alex
- mdgm-ntgrNETGEAR Employee RetiredHave you seen this suggestion?: http://www.readynas.com/forum/viewtopic.php?p=345654#p345654
- grooovyAspirantThanks for replying, mdgm!
I tried this one with no success. :( - mdgm-ntgrNETGEAR Employee RetiredCan you download your logs (On the Dashboard, click Configure, then select Health > Logs > Download Logs). What does your upnp-av.log look like?
- grooovyAspirantThanks for your help!
Sure. Here it is:
[2012/03/08 23:02:11] minidlna.c:885: warn: Starting ReadyDLNA version 1.0.24.
[2012/03/08 23:02:11] minidlna.c:911: warn: Creating new database...
[2012/03/08 23:02:11] minidlna.c:988: warn: HTTP listening on port 8200
[2012/03/08 23:02:11] minidlna.c:1000: warn: TiVo support is enabled.
[2012/03/08 23:02:11] scanner.c:727: warn: Scanning /c/media
[2012/03/08 23:02:11] upnpsoap.c:1739: warn: Returning UPnPError 402: Invalid Args
[2012/03/08 23:02:12] scanner.c:798: warn: Scanning /c/media finished (3 files)!
[2012/03/08 23:02:12] playlist.c:125: warn: Parsing playlists...
[2012/03/08 23:03:30] minidlna.c:153: warn: received signal 15, good-bye
[2012/03/08 23:05:07] minidlna.c:885: warn: Starting ReadyDLNA version 1.0.24.
[2012/03/08 23:05:07] minidlna.c:988: warn: HTTP listening on port 8200
[2012/03/08 23:05:07] minidlna.c:1000: warn: TiVo support is enabled.
[2012/03/08 23:09:37] minidlna.c:153: warn: received signal 15, good-bye
[2012/03/08 23:11:13] minidlna.c:885: warn: Starting ReadyDLNA version 1.0.24.
[2012/03/08 23:11:13] minidlna.c:988: warn: HTTP listening on port 8200
[2012/03/08 23:11:13] minidlna.c:1000: warn: TiVo support is enabled.
[2012/03/08 23:19:57] minidlna.c:153: warn: received signal 15, good-bye
[2012/03/08 23:21:39] minidlna.c:885: warn: Starting ReadyDLNA version 1.0.24.
[2012/03/08 23:21:39] minidlna.c:988: warn: HTTP listening on port 8200
[2012/03/08 23:21:39] minidlna.c:1000: warn: TiVo support is enabled.
[2012/03/08 23:30:20] playlist.c:125: warn: Parsing playlists...
[2012/03/08 23:31:00] minidlna.c:153: warn: received signal 15, good-bye
[2012/03/08 23:34:04] minidlna.c:885: warn: Starting ReadyDLNA version 1.0.24.
[2012/03/08 23:34:04] minidlna.c:988: warn: HTTP listening on port 8200
[2012/03/08 23:34:04] minidlna.c:1000: warn: TiVo support is enabled.
[2012/03/08 23:38:09] minidlna.c:153: warn: received signal 15, good-bye
[2012/03/09 22:57:10] minidlna.c:885: warn: Starting ReadyDLNA version 1.0.24.
[2012/03/09 22:57:10] minidlna.c:988: warn: HTTP listening on port 8200
[2012/03/09 22:57:10] minidlna.c:1000: warn: TiVo support is enabled.
Thank you for looking into this!
Have a terrific weekend.
Alex - mdgm-ntgrNETGEAR Employee RetiredSo should it have found 3 files in total?
- grooovyAspirant
- mdgm-ntgrNETGEAR Employee RetiredYou might wish to try the Debug Toggle add-on (http://www.readynas.com/forum/viewtopic.php?f=76&t=27946) then rebuild the database again, and download the logs again. Then open a tech support (http://www.readynas.com/support) case and send in the upnp-av.log. Maybe they'll have some ideas.
- grooovyAspirantYes. Files were found. But I am unable to play any of them. :(
Videos length is zero and I cannot play them from NAS where as I am able to play the same files via DLNA set up in Windows Media PLayer.
Very strange... :( - grooovyAspirantOK. Thanks for your help!
- grooovyAspirantMusic and photos are displaying fine now! But videos - don't :(
Sent a request to support team.
