× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Netgear NV+ Raidar error
Martyn-E
I had to do a factory reset on the NAS NV+, when I try to log in through Raidar Admin page I get the message " This site can't provide a secure connection 192.168.1.130 uses an unsupported protocol. ERR_SSL_VERSION_OR_CIPHER_MISMATCH
I expect the firmware is out of date, but I can not see how to update it without access to Raidar.
My computer is a Mac running Monterey 12.6, I have updated Raidar Ido not know how to check the firmware  the NAS is running.
the Ready NAS is an NV+ RND4000
Can anyone help please ?
Message 1 of 3
Guru
Re: Netgear NV+ Raidar error
Current firmware also has this problem.  The NAS web server only supportsTLS 1.0, and the browsers now require TLS 1.2.
The best option on a Mac is to install an old version of FireFox (94.0.2 works) - configuring it to not autoupdate.  You won't be able to connect from RAIDar unless you make FireFox the default browser (which I don't recommend). But you can access the web ui directly by browsing to https://nas-ip-address/admin (using the real IP address of course).
Once you have access, there are a couple of options on how to proceed (including just continuing to use the old FireFox browser to access the NAS). More information on this topic is here:
Note the options depend on whether you have an NV+ or an NV+ v2.  Go by the front panel for this check, as other labels are misleading.  The v2 says "ReadyNAS NV+ v2" on the front panel, the original NV+ (called a v1 here) says "ReadyNAS NV+".
Message 2 of 3
Martyn-E
Thank you for you information, I am not willing to run on a old firmware I will have to get rid of the NAS.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 546 views
  • 0 kudos
  • 2 in conversation
Announcements
