Gshavzin
Feb 09, 2018Aspirant
ReadyDLNA does not enable
Readynas DLNA does not enable. I have tried the solutions listed on the site with no luck. I get the you must have a volume error sometimes. Mostly the service never enables even though I have it enabled on the shares themselves. I went back to 6.9.1 manually then back to 6.9.2 again. It made no difference. I also can’t see any apps anymore. I don’t think I even had any installed, but I can’t be sure. My only want is to have my new LG tv see my ReadyNAS. The tv saw it the first day I had it, but the second day it disappeared. I restarted the NAS and upgraded the firmware to try to resolve it. Any help would be greatly appreciated.
thanks,
Greg
I don't understand what you are saying here. You shouldn't be getting volume errors on your NAS.
Netgear might be interested in analyzing your logs, so you might wait a bit to give them time to respond.
One possibility is that a corrupted media file is causing ReadyDLNA to crash when it scans. You might try turning ReadyDLNA off on all your folders, and then see if you can enable the service. If that works, then you can enable ReadyDLNA one share at a time (doing a full manual scan before moving to the next). That would help you discover what share the corrupted media is in.
- GshavzinAspirant
It cannot be corrupted data. I’m running 2 drives in JBOD. Different data on the drives. I can enable any service I desire (NFS, SMB, AFP, FTP). The files share perfectly otherwise. I just need my new TV to see it and that requires DLNA. I even tried to enable DLNA and not rescan. I saw this answer you gave to another user. I will grab logs and be ready for Netgear to respond.
Thanks,
Greg
You might be right, but the info you've provided so far doesn't rule it out. The test I suggested would.
FWIW, you could also install plex (which includes it's own DLNA server). But it'd be better to sort out what is happening with ReadyDLNA, since ReadyDLNA failing could be a symptom of a bigger problem.
