Kberna1376
May 24, 2016Apprentice
ReadyNAS 204 not showing up in file explorer
Selecting the NAS I get a message than windows cannot access \\<server id>. Network path not found. I use Adobe Lightroom and cannot access any of the photos on the NAS. All this happened after the update to 6.5! How can I fix this!
- JennCNETGEAR Employee Retired
Hello Kberna1376,
Can you still access the admin page? If so, please check if SMB is enabled still. If not, please run RAIDar and see if it will detect your ReadyNAS.
Do you have ReadyCloud desktop client installed at the same time to the computer that is also logged in? If so, please log it out, make sure it is updated to 1.12 version. You ReadyCloud account should also be upgraded to the myNetgear account.
- Kberna1376Apprentice
I can log into the NAS and see the admin page. SMB is enabled. I have upgraded to a MyNetgear account, and have the latest 1.12 version of Ready Cloud. Everything seems to be working as before, but windows 10 just doesn't allow access to the NAS in the file explorer. It sees the NAS but I get the error that windows cannot acess the server.
Video and music streaming services are working perfectly. Video is streaming to a WDTVLive, and music streams to Sonos.
The big problem is there is not access to my pictures from my Adobe Light Room software.
Hello Kberna1376,
Please try what they did at https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyNAS-Duo-v2-amp-Windows-10/td-p/973595
- Retired_MemberOn other threads, users had to remove "saved" sets of credentials from Windows. If you search for "manage network password", you can remove the old sets of credentials for your nas, and create a fresh set. Once done, try access the smb share again.
I tried this, and no success.
This does not solve the problem. Still get the error when trying to access the NAS from file explorer. This is what is blocking my Adobe Lightroom from accessing my photos. As mentioned, other services for streaming video and music work great, but no access to the server via explorer.
