Psyclone's avatar
Psyclone
ReadyNAS NV+ Support for EXT4
  •  ReadyNAS RND4000 with (4) 500GB drives
  • Runing RAIDiator 4.1.14 which is the latest.
Is there any means to update or install an addon that allows this older model ReadyNAS to read a USB device with EXT4 format? It appears EXT3 is supported, but I have an EXT4 formated drive from a DVR that I would like to ready via the USB ports on the ReadyNAS.
  • Hello Psyclone,
    Unfortunately, your ReadyNAS NV+ v1 is a Sparc based NAS which is the same architecture as ReadyNAs Duo v1. Sparc-based NAS is a discontinued NAS series and does not support EXT4, there is no update nor SW that will make this support EXT4. Please click here to see the same topic that was answered too.
    Welcome to the community!
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello Psyclone,
    • Psyclone's avatar
      Psyclone
      Thank you. Not the answer I wanted, but appreciate it. I searched for quite some time before posting the question. It's easy to get lost with all the models and what the processor is in them, especially these older units. I installed my ReadyNAS years ago and other than a power suppy failure has been trouble free.
      • mdgm-ntgr's avatar
        mdgm-ntgr
        All our currrent model ReadyNAS support USB drives formatted with the EXT4 filesystem. If you must use the EXT4 filesystem on the USB disk it might be time to consider getting a new ReadyNAS. You can seek pre-sales advice on the community. Ask questions and provide general information on what you use your NAS for, how much data you currently have and how quickly you would project this to grow, budget etc. and some good suggestions could be made.
ProSupport for Business
