rus44's avatar
rus44
Follower
Aug 17, 2016
Readynas nv+ v2 - problem with apt-get
Hi, I am trying to run an apt-get update on my readynas and it's failing with.....
apt-get update
Hit http://security.debian.org squeeze/updates Release.gpg
Ign http://security.debian.org/ squeeze/updates/main Translation-en
Ign http://ftp.us.debian.org squeeze Release.gpg
Ign http://ftp.us.debian.org/debian/ squeeze/main Translation-en
Ign http://ftp.us.debian.org squeeze-updates Release.gpg
Ign http://ftp.us.debian.org/debian/ squeeze-updates/main Translation-en
Hit http://security.debian.org squeeze/updates/main Sources
Hit http://security.debian.org squeeze/updates/main armel Packages
Ign http://ftp.us.debian.org squeeze/main Sources/DiffIndex
Ign http://ftp.us.debian.org squeeze/main armel Packages/DiffIndex
Ign http://ftp.us.debian.org squeeze-updates/main Sources/DiffIndex
Ign http://ftp.us.debian.org squeeze-updates/main armel Packages/DiffIndex
Err http://ftp.us.debian.org squeeze/main Sources
404 Not Found [IP: 128.61.240.89 80]
Err http://ftp.us.debian.org squeeze/main armel Packages
Err http://ftp.us.debian.org squeeze-updates/main Sources
Err http://ftp.us.debian.org squeeze-updates/main armel Packages
W: Failed to fetch http://ftp.us.debian.org/debian/dists/squeeze/main/source/Sources.gz 404 Not Found [IP: 128.61.240.89 80]
W: Failed to fetch http://ftp.us.debian.org/debian/dists/squeeze/main/binary-armel/Packages.gz 404 Not Found [IP: 128.61.240.89 80]
W: Failed to fetch http://ftp.us.debian.org/debian/dists/squeeze-updates/main/source/Sources.gz 404 Not Found [IP: 128.61.240.89 80]
W: Failed to fetch http://ftp.us.debian.org/debian/dists/squeeze-updates/main/binary-armel/Packages.gz 404 Not Found [IP: 128.61.240.89 80]
E: Some index files failed to download, they have been ignored, or old ones used instead.
/etc/sources.lst contents are
# deb http://ftp.us.debian.org/debian/ squeeze main
deb-src http://ftp.us.debian.org/debian/ squeeze main
deb http://security.debian.org/ squeeze/updates main
deb-src http://security.debian.org/ squeeze/updates main
deb http://ftp.us.debian.org/debian/ squeeze-updates main
deb-src http://ftp.us.debian.org/debian/ squeeze-updates main
squeeze is very old now so I would like to know if there is there a way to allow the system to update or does it now have to remain on an old version forever now?
1 Reply
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    If you set a static I.P. did you remember to specify the DNS server addresses? You could try adding Google DNS (8.8.8.8)
    Installing packages from newer Debian distributions would likely break things. It is stuck on squeeze.
ProSupport for Business
