stgeorge
Apr 06, 2012Guide
Reset Network Configuration
So I brought my Duo to a new network temporarily, and forgot to reset the network configurations to connect dynamically (from my fixed settings on its home network). Can someone please remind me how to reset the network configurations on a duo so I can get it to connect to this network and I can take it from there?
Thanks
Thanks
- ReadySECUREApprenticeAn OS reinstall will reset the NIC settings and the Frontview sign in.
If you need the guide as well, here it is: http://www.readynas.com/kb/faq/boot/how ... _boot_menu
The other option would be a direct connection to the NAS. Alter your NIC settings on the machine to match the home subnet, and then manually alter the NIC settings back to DHCP or static to the present network. - ReadySECUREApprenticeDid everything work out well StGeorge? or did you have additional complications?
