DGio's avatar
DGio
Rsync over SSH reverts to OS volume when Delete Files is che
I am running RSYNC OVER REMOTE SSH backups from a ReadyNAS 316 to an NVX on the same network.
This works great until I check the box to Remove Deleted Files on Target.
Here's the log BEFORE asking the 316 to Remove Deleted Files on Target:
Backup Job Name: T3 to T1
Backup Job Type: Incremental
Protocol: rsync+ssh
Backup Source: [David]/
Backup Destination: [remote:rsync+ssh]/192.168.10.201://T3-Backup/
Backup Start Time: Sat Oct 18 2014 19:00:21
Backup Finish Time: Sat Oct 18 2014 19:00:23
Backup Status: Success
Here's the log AFTER asking to Remove Deleted Files on Target:
Protocol: rsync+ssh
Backup Start Time: Sat Oct 18 2014 19:00:44
Backup Finish Time: Sat Oct 18 2014 19:00:45
Backup Status: Fail: error in data stream. Please check remote rsync server settings.
The ReadyNAS OS volume cannot be used as an rsync source or destination.
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: error in rsync protocol data stream (code 12) at io.c(605) [sender=3.0.9]
The simple act of checking the Delete Files box seems to point rsync to the OS directory.
Is this a bug or a feature? Is there a work-around? If I'm doing something wrong I'm happy to get schooled.
Thanks in advance for your help.
  • The 316 is running 6.1.9.
    The NVX is running 4.2.15.
    I have the same problem running rsync over SSH backup to a Pro 4 running 4.2.27. The issue seems to be with OS 6.1.9.
    Thanks
ProSupport for Business
