blacknirvana's avatar
blacknirvana
[SOLVED] ReadyNAS Duo, XBMC and NFS
Hi all
I'm new to this and have searched the internet for a helpfull guide with no luck :(
I want to access the media files on my readynas duo through XBMC. First I attempted to use the UPnP streaming service bit found that it creates a problem with the library due to the way files urls are handled. Then I used SMB for a while but find it creates a bit of lag and doesn't work correctly with HD movies, on the XBMC website they suggest to use NFS instead, and now I need help :)
I activated NFS in the ReadyNas Frontview, then I have set the NFS access to read/write for the correct share (again through Frontview).
I know the IP adress but whenever I try to add it as a source in XBMC it comes up with a "cannot connect error".
Ís my path right? "nfs://IP/media/movies" (the share is "media" and the subfolder is "movies")
What am I missing?
1 Reply
  • Figured it out, had to change to the latest nightly build of XBMC for it to work.
ProSupport for Business
