Xplore
Jan 29, 2015Aspirant
Setting up DDclient
Hi all,
I would like to setup DDclient to update my dns
So I got an account at http://freedns.afraid.org/
I understand that I have to edit ddclient.conf
But I have no clue what to put in there.
About the editing: I would like to do this using notepad++ and the NppFTP plugin after enabling SSH on the NAS
Could someone point me in the right direction about what to put in ddclient.conf ?
Thanks
Thanks
- XploreAspirantAh man,
Do I fail to get the concept of these apps for my NAS ?
When I click available/installed apps on my admin page I see DDclient V1.0.0 installed
When I go to rnxtras it seems V 3.8.2 is available for $3.29 ??
What is this ? Why does V1.0.0 show up in "available apps" to install, is it outdated ?
Sorry but is is a bit confusing... - mdgm-ntgrNETGEAR Employee RetiredYou are looking at an add-on for a different model NAS with a different CPU architecture running a different firmware.
R4Sparc is referring to RAIDiator 4.1.x on the Duo (v1) and NV+ (v1). Add-ons for legacy ReadyNAS devices are not compatible with OS6.
Your NAS is running OS6. - XploreAspirantOK, thanks.
So DDclient V1.0.0 should work on my RN102 ?
The question remains how I should edit this file to have DDclient update my IP at freedns.
Thanks - algiamAspirantI have it this way and it works perfectly. Use a No-IP domain.
protocol=noip
use=web, web=checkip.dyndns.com, web-skip='IP Address'
server=dynupdate.no-ip.com
login=xxxxxxxx@gmail.com
password='xxxxxxxx'
xxxxxxxxx <----- domain name - RockmanAspirantLet's get really basic here first with my NS Pro
1. When the download unzips, a lot looks like Linux which used very occasionally about 15yrs ago.
2. Any idea on what the "Image" file might be that has to be used in "Add-ons/Add New"; maybe just the file labelled "ddclient" since that appears to be a script of some sort.
3. Several posts here and elsewhere have talked of editing the configuration file which is where things get a little fuzzy. The main thing is where is it at? Windows Explorer only shows my shares and their files. There are configuration files with the download but they aren't on my NS Pro.
Sorry for the simple questions but in the last 20yrs or so, I've gotten to be a PnP old man in retirtement.
Thanks for the help
