Crofty7
Jan 17, 2019Aspirant
Soon to run out of capacity and do i need a back up of a backup?
I have a ReadyNAS 212 with 2TB HDD. I'm slowly filling it up so i need to expand. I also thought that the ReadyNAS would work as a server and backup through the RAID thingy. Is this a novice mistake to make??
I would like to expand to at least 10TB but unsure how best to do it. Do i....
1. purchase another 2 bay NAS and install 10TB drives throught out and link them together, one acting as a backup for the other?
2. purchase a 4 bay NAS and somehow get two drives working as server and raid thingy and the other as the backup and raid thingy?
3. stick with what i've got and just increase the HDD size?
4. consider a backup of the NAS to the cloud/remote HDD??
Well, if the NAS is used for primary storage then you need a copy of those files somewhere else. RAID isn't enough to keep the data safe.
If you are using it for backup storage (meaning you have at least one other copy), then the data is much safer, since if either device fails you still have the other copy. Though personally I've had my backups fail when I needed them, so my own policy is to keep at least 3 copies of anything I care about.
This does provide a backup, though you should also price a 4 bay NAS. An RN214 sells for about $50 more than an RN212 at the moment. That gives you empty slot(s) for future expansion.
You really should backup to another device. You can easily lose both the primary and backup volumes if they are in the same NAS. A power failure when the backup is running is one of several ways that can happen.
You could do that, if you are willing to risk data loss. I don't recommend it. Data recovery is uncertain and expensive. So at least add USB disks for local backup.
This is a reasonable approach to backup. I use cloud backup myself for disaster recovery (protecting from theft, power surges, etc).
A couple of caveats:
- you are trusting the cloud provider to keep your data safe. Personally I'm not comfortable having my only backup in the cloud.
- two-way sync isn't a good approach for backup, since if either copy is compromised, the compromised copy will be copied back onto the other device. So make sure you are doing a one-way backup, not a two-way sync.
- Cloud backup will be much slower than a local one. If you have ~10 TB of data, it can take several months to get everything backed up (or everything restored). Another reason why I combine cloud backup with local backup.
- Crofty7Aspirant
I use the NAS as a server to keep the laptop free of documents and photos. I also use office 365 fo document cloud storage on OneDrive. I will at some point need to back this up to the NAS.
Would you agree to this as being my best approach?
Purchase a 4 bay NAS (advice on best type would be greatly appreciated) and use two slots until i require more space
Purchase a USB HDD (what is quickest? USB or SATA?) and backup what's on the NAS. store this HDD at my parents for safe keeping.
Crofty7 wrote:
- Purchase a 4 bay NAS (advice on best type would be greatly appreciated) and use two slots until i require more space
- Purchase a USB HDD (what is quickest? USB or SATA?) and backup what's on the NAS.
- Store this HDD at my parents for safe keeping.
It's a good approach. Using two USB drives might be a small improvement - doing more frequent backups at home, and then swapping it with the one at your parents periodically.
The RN214 is a good entry-level NAS. You could also go with the RN424 (about $150 more expensive at the moment).
As far as the drive type goes a USB 3 drive is a good option. Get one that has it's own power adapter. I'd format it as NTFS, so you can read the files with a PC.
