BPBear's avatar
BPBear
Time Machine Cannot Connect to ReadyNAS
"Time Machine can't connect to the backup disk." Been using TM with ReadyNAS 214 for some time, but now the connection fails. This is the message I get when I try to sign in to my RNas from Time Machine. The User Name and Password used are the same ones I have always used to make a direct connection to my RNas web interface. I only use the Private Time Machine I set up months ago. But now TM is failing to connect.
I run macOS Monterey v.12.6.3 on an iMac, and My ReadyNAS 214 is running the latest Firmware, v.6.10.8.
Any suggestions to get around the connection failure?
Thanks
ProSupport for Business
