× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
What Is upgrade option for RN316
2007
Hi,
We have currently using RN316 network Storage. now its discontinued and no longer support available. can you please suggest what best option is available for the same? is we can transfer data from old NASBOX to NEW NASBOX?
regards,
Viraj
Message 1 of 4
Accepted Solutions
Guru
Re: What Is upgrade option for RN316
@2007 wrote:
Hi,
Netgear hasn't launched a new ReadyNAS product since 2017, so they appear to be quiet-quitting their storage business. If you want to migrate to a new NAS, you'll need to select a different vendor.
You could use the RN316 as a backup NAS (you can use rsync for this, as it is commonly supported on all linux-based NAS).
FWIW, the link in rupindersingh's reply is not relevant, as you don't have a ReadyNAS that runs 4.2.x firmware.
Message 3 of 4
All Replies
rupindersingh
Initiate
Welcome to the Community!
Since you already have a backup of your data, it will be easier for you to just reformat the disks and then restore the data afterwards.
Just in case that your backup is not up-to-date, there is a process on how you can access the data using the new NAS and offload it temporarily to an alternate location (external USB HD, network share, etc.). You may check this link for the procedure.
Message 2 of 4
Guru
@2007 wrote:
Hi,
Message 3 of 4
2007
Thank you for the suggestion.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1279 views
  • 2 kudos
  • 3 in conversation
Announcements
