× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Where to find BIOS updates - Ultra4 Plus
itsjasper
Luminary
I've had no luck searching for the v1.10 BIOS update for the ReadyNAS Ultra 4 without success.
Could someone pint me in the direction to download it please?
Currently running OS6 on this unit but I'm happy to downgrade to OS4 to do the BIOS update if need be.
Model: ReadyNASRNDP400U|ReadyNAS Ultra 4 Plus Chassis only
Message 1 of 4
Accepted Solutions
itsjasper
Luminary
Re: Where to find BIOS updates - Ultra4 Plus
Thanks, as this was a new unit for me, I downgraded to OS4, ran the BIOS update and went back to OS6.
Message 4 of 4
All Replies
mdgm-ntgr
NETGEAR Employee Retired
No need to downgrade to OS4.
Here's the add-on
The latest BIOS for the Ultra 4/Ultra 4 Plus/Pro 4 is from 23rd August 2011
You can install flashrom and dmidecode using apt-get, extract the contents of the add-on and run the command to flash the BIOS manually doing something like this:
# apt-get update
# apt-get install dmidecode flashrom
# cd /tmp
# wget http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin
# dd if=BIOS_Update_Package_0.5-x86.bin bs=16k count=1
# dd if=BIOS_Update_Package_0.5-x86.bin bs=16k skip=1 | md5sum -
# dd if=BIOS_Update_Package_0.5-x86.bin bs=16k skip=1 | tar -xv
# tar -xvf files.tgz
# ls -lah /tmp/opt/biosflash
# flashrom --programmer internal -c SST25VF016B -w /tmp/opt/biosflash/RN_Ultra4_082311.ROM
 Don't interrupt that last command. Updating the BIOS if interrupted can leave the system in a state where it will brick when next powered off.
Message 2 of 4
Sandshark
Sensei
Have you tried that method under OS 6.6.x?  It didn't work for me because flashrom wouldn't execute.  See Updating-motherboad-BIOS-from-OS6-can-t-get-it-to-work.  There has since been a suggestion that a 32-bit C library is needed, but I have not tried that.
Message 3 of 4
itsjasper
Luminary
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4746 views
  • 3 kudos
  • 3 in conversation
Announcements
