Retired_Member
Jul 22, 2018XRAID Hard-Drive Speeds?
Hi all,
Ever since the NAS OS was re-installed and I did some maintance on the NAS (test disks -> scrub -> balance -> defrag) I've been experienicng slow transfer rates.
I have run the following for the hard drive speeds on the NAS, to see if there is any read/write issue, but I don't know if the follow is slow or normal:
***@NAS:/media/USB_HDD_2$ dd bs=1M count=256 if=/dev/zero of=test oflag=dsync 256+0 records in 256+0 records out 268435456 bytes (268 MB, 256 MiB) copied, 4.55748 s, 58.9 MB/s ***@NAS:/media/USB_HDD_2$ cd /data/Sharing/ ***@NAS:/data/Sharing$ dd bs=1M count=256 if=/dev/zero of=test oflag=dsync 256+0 records in 256+0 records out 268435456 bytes (268 MB, 256 MiB) copied, 21.7408 s, 12.3 MB/s
If anyone else can please post their drive speed test results to compare with, it would be appreaciated.
Thanks
- Retired_MemberJul 22, 2018
removed network bonding and appears to have speed up network transfers considerably (46Mbs)
- Retired_Member
Just some further info:
Here are the (concerning) transfer rates across the LAN (albiet, its PC <-> wireless <-> router (gig) <-> 2xcat6 -> NAS, but see below as there are no PC wifi issues with the internet speeds):
***@PC: NAS performance tester -
Running a 100MB file write on Z: once... ----------------------------- Average (W): 0.29 MB/sec ----------------------------- Running a 100MB file read on Z: once... ----------------------------- Average (R): 0.38 MB/sec -----------------------------The network speeds - NAS (client): ***
***@NAS: iprerf -c
Server listening on TCP port 5001 TCP window size: 85.3 KByte (default) ------------------------------------------------------------ ------------------------------------------------------------ Client connecting to 10.1.1.4, TCP port 5001 TCP window size: 196 KByte (default) ------------------------------------------------------------ [ 5] local 10.1.1.250 port 38606 connected with 10.1.1.4 port 5001 [ 4] local 10.1.1.250 port 5001 connected with 10.1.1.4 port 13830 [ ID] Interval Transfer Bandwidth [ 4] 0.0-10.0 sec 3.88 MBytes 3.25 Mbits/sec [ 5] 0.0-10.0 sec 1.50 MBytes 1.26 Mbits/sec [ 4] 10.0-20.0 sec 3.12 MBytes 2.62 Mbits/sec [ 5] 10.0-20.0 sec 1.12 MBytes 944 Kbits/sec [ 4] 20.0-30.0 sec 4.12 MBytes 3.46 Mbits/sec [ 5] 20.0-30.0 sec 1.38 MBytes 1.15 Mbits/sec [ 4] 30.0-40.0 sec 3.00 MBytes 2.52 Mbits/sec [ 5] 30.0-40.0 sec 1.88 MBytes 1.57 Mbits/sec [ 4] 40.0-50.0 sec 3.10 MBytes 2.60 Mbits/sec [ 5] 40.0-50.0 sec 2.75 MBytes 2.31 Mbits/sec [ 4] 50.0-60.0 sec 3.34 MBytes 2.80 Mbits/sec [ 4] 0.0-60.5 sec 20.8 MBytes 2.88 Mbits/sec [ 5] 50.0-60.0 sec 1.75 MBytes 1.47 Mbits/sec [ 5] 0.0-61.4 sec 10.5 MBytes 1.43 Mbits/secwith (PC) server results:
***@PC: iperf -s
Server listening on TCP port 5001 TCP window size: 208 KByte (default) ------------------------------------------------------------ [ 4] local 10.1.1.4 port 5001 connected with 10.1.1.250 port 38606 ------------------------------------------------------------ Client connecting to 10.1.1.250, TCP port 5001 TCP window size: 208 KByte (default) ------------------------------------------------------------ [ 5] local 10.1.1.4 port 13830 connected with 10.1.1.250 port 5001 [ ID] Interval Transfer Bandwidth [ 5] 0.0-60.3 sec 20.8 MBytes 2.89 Mbits/sec [ 4] 0.0-63.1 sec 10.5 MBytes 1.40 Mbits/secInternet Speeds - NAS (2xCat6): ***
***@NAS: wget -O
Testing download speed................................................................................ Download: 3.87 Mbit/s Testing upload speed................................................................................................ Upload: 3.73 Mbit/sInternet Speeds - PC (wireless)
***@PC: testmy.net
:::.. Internet Speed Test Result Details ..::: Download Connection Speed:: 14951 kbps or 15 Mbps Download Speed Test Size:: 54 MB or 55296 kB or 56623104 bytes Download Binary File Transfer Speed:: 1869 kB/s or 1.9 MB/s Upload Connection Speed:: 12794 kbps or 12.8 Mbps Upload Speed Test Size:: 6.3 MB or 6464 kB or 6619136 bytes Upload Binary File Transfer Speed:: 1599 kB/s or 1.6 MB/s Timed:: Download: 30.298 seconds | Upload: 4.139 seconds*** Appears there is an issue on the NAS / NIC / Cat 6 Cables or possibly the Router Ethernet (2x1000 Mbps ETH router ports, however there are no errors/failures showing on the router stats):
***@Router: Network Statistics Interface Rx Bytes Tx Bytes Rx Packets Tx Packets Rx Errors Tx Errors Port 1 121842790 352682623 180885 298305 0 0 Port 2 121461967 342355930 180585 287286 0 0 WiFi-2.4Ghz 440897786 843543447 543961 816870 0 0 WiFi-5Ghz 50735 6453765 527 16359 0 0
- Retired_Member
Not sure why you are using oflag=dsync, so I ran the command both ways. This is on an RN526x with 4x6TB WD60EFRX drives.
root@NAS:/data/Test# dd bs=1M count=256 if=/dev/zero of=test oflag=dsync 256+0 records in 256+0 records out 268435456 bytes (268 MB, 256 MiB) copied, 28.2462 s, 9.5 MB/s root@NAS:/data/Test# dd bs=1M count=256 if=/dev/zero of=test 256+0 records in 256+0 records out 268435456 bytes (268 MB, 256 MiB) copied, 0.61322 s, 438 MB/s root@NAS:/data/Test#
removed network bonding and appears to have speed up network transfers considerably (46Mbs)You should be seeing ~100 MB/sec for large sequential file transfers over a gigabit network. Perhaps re-run iperf and see what your raw network speeds are without bonding.
What bonding mode were you using on the NAS (and what mode did you have enabled on the switch)?
Also, what MTU are you using on the NAS?
- Retired_Member
I believe dsync (data only sync, no meta data) writes sequentially and ensures write cache isn't used or kept to a min (buffer flushed out evey block)...where as direct bypasses linux page cache, however writes concurrently. I'm not sure if there is an option to write sequentially and bypass linux page cahe altogether, so I used dsync for sequential writing for a more accurate write speed. Not that it really matters when comparing the same tests, but it does minimize variance in influence.
(testing with some unavoidable hard-drive use):
***@NAS:~$ dd bs=1M count=256 if=/dev/zero of=test oflag=dsync 256+0 records in 256+0 records out 268435456 bytes (268 MB, 256 MiB) copied, 22.7576 s, 11.8 MB/s ***@NAS:~$ dd bs=1M count=256 if=/dev/zero of=test oflag=direct 256+0 records in 256+0 records out 268435456 bytes (268 MB, 256 MiB) copied, 4.33843 s, 61.9 MB/s
256+0 records in
256+0 records out
268435456 bytes (268 MB, 256 MiB) copied, 0.849287 s, 316 MB/sAppears the hard-drive speeds are comparable - phew :)
Config: NAS MTU=1500, same as router.
CPE: NAS 2x1gb <-> 2xcat 6 <-> 2x1gb router ports <-> cat6 <-> 1xgb pc
I was using round-ribbon bonding, but appears ok now after swapping out the ethernet cables. I appear to be getting around the 750-890Mbps range, which is around 100MB/sec.
***@PC: iperf -c 10.1.1.250 -i 5 -d ------------------------------------------------------------ Server listening on TCP port 5001 TCP window size: 208 KByte (default) ------------------------------------------------------------ ------------------------------------------------------------ Client connecting to 10.1.1.250, TCP port 5001 TCP window size: 208 KByte (default) ------------------------------------------------------------ [ 4] local 10.1.1.89 port 3937 connected with 10.1.1.250 port 5001 [ 5] local 10.1.1.89 port 5001 connected with 10.1.1.250 port 33836 [ ID] Interval Transfer Bandwidth [ 4] 0.0- 5.0 sec 447 MBytes 749 Mbits/sec [ 4] 5.0-10.0 sec 531 MBytes 891 Mbits/sec [ 4] 0.0-10.0 sec 978 MBytes 820 Mbits/sec
It looks like you've sorted it out.
On the bonding - if you are using round-robin in the NAS, then you need to have a static LAG set up on the switch/router. I don't know of any home router that supports static LAGs. A couple of home routers (for instance the Netgear R8500) supports LACP bonding - if you have one of those you could try that. Or you could try using TLB or ALB, as they are the two modes that don't require router/switch support.
Though as I mentioned earlier, with link aggregation the router->client connection becomes the bottleneck - so you won't see any speed increase for a single connection using wireless or gigabit. You would see a gain only if you have multiple clients accessing the NAS simultaneously. So you could just leave well enough alone, and use a single ethernet connection on the NAS.
