Petroc
Sep 04, 2020Aspirant
rn214not expanding
i have a readynas 214 with 1x 4tb an thd 3 x 3tb hoever the capacity is coming outon the admin page as 6.35 tb i think i should be getting in the region of 7.4tb based on the readynas calculator giving 8.26tiB x 0.9095 conversion tiB to TB although thes um of all srives lesslargest = 9 is that the correct raid 5 calculation for array capacity?
eith eay f its not expandibg correctly how can i fix? ideally without having to delet the volume and recreating then restoring backup. as the backup does not include my time machine bckups
the
tia
- SandsharkSensei
And XRAID is enabled?
A TB is smaller than a TiB, so you did the conversion wrong. You should be getting 8.16TiB. But I think the NAS thinks you still have two 2TB drives and either two 3TB or one 3TB and one 4TB (because the extra 1TB of 4 would currently be unused). That indicates that the expansion problem occurred before you made your latest disk swap.
If you post the contents of mdstat.log from the downloaded log .zip file (using the </> "code" tool in the forum works best) and describe the starting drive configuratrion and what changes have been made along the way, we may be able to see if there is a way to fix it.
- PetrocAspirant
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md126 : active raid5 sda4[4] sdd4[3] sdb4[1] 3906745856 blocks super 1.2 level 5, 64k chunk, algorithm 2 [3/3] [UUU] resync=DELAYED md127 : active raid5 sda3[6] sdd3[4] sdc3[5] sdb3[1] 2915738496 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU] [==================>..] resync = 90.5% (880496640/971912832) finish=46.4min speed=32810K/sec md1 : active raid10 sda2[0] sdd2[3] sdc2[2] sdb2[1] 1046528 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU] md0 : active raid1 sda1[6] sdd1[4] sdc1[5] sdb1[1] 4190208 blocks super 1.2 [4/4] [UUUU] unused devices: <none> /dev/md/0: Version : 1.2 Creation Time : Tue Feb 20 20:47:29 2018 Raid Level : raid1 Array Size : 4190208 (4.00 GiB 4.29 GB) Used Dev Size : 4190208 (4.00 GiB 4.29 GB) Raid Devices : 4 Total Devices : 4 Persistence : Superblock is persistent Update Time : Sat Sep 5 08:02:34 2020 State : clean Active Devices : 4 Working Devices : 4 Failed Devices : 0 Spare Devices : 0 Consistency Policy : unknown Name : 568aca8b:0 (local to host 568aca8b) UUID : 6ca489e0:ea2dfd6f:1330a41a:83693582 Events : 5723 Number Major Minor RaidDevice State 6 8 1 0 active sync /dev/sda1 1 8 17 1 active sync /dev/sdb1 5 8 33 2 active sync /dev/sdc1 4 8 49 3 active sync /dev/sdd1 /dev/md/1: Version : 1.2 Creation Time : Thu Sep 3 19:36:40 2020 Raid Level : raid10 Array Size : 1046528 (1022.00 MiB 1071.64 MB) Used Dev Size : 523264 (511.00 MiB 535.82 MB) Raid Devices : 4 Total Devices : 4 Persistence : Superblock is persistent Update Time : Sat Sep 5 07:54:47 2020 State : clean Active Devices : 4 Working Devices : 4 Failed Devices : 0 Spare Devices : 0 Layout : near=2 Chunk Size : 512K Consistency Policy : unknown Name : 568aca8b:1 (local to host 568aca8b) UUID : e083319b:882c0819:3d5e4ae3:d4d4c232 Events : 19 Number Major Minor RaidDevice State 0 8 2 0 active sync set-A /dev/sda2 1 8 18 1 active sync set-B /dev/sdb2 2 8 34 2 active sync set-A /dev/sdc2 3 8 50 3 active sync set-B /dev/sdd2 /dev/md/data-0: Version : 1.2 Creation Time : Tue Feb 20 20:48:03 2018 Raid Level : raid5 Array Size : 2915738496 (2780.66 GiB 2985.72 GB) Used Dev Size : 971912832 (926.89 GiB 995.24 GB) Raid Devices : 4 Total Devices : 4 Persistence : Superblock is persistent Update Time : Sat Sep 5 08:02:38 2020 State : clean, resyncing Active Devices : 4 Working Devices : 4 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Consistency Policy : unknown Resync Status : 90% complete Name : 568aca8b:data-0 (local to host 568aca8b) UUID : 55af480e:f05a8c92:bc26929e:bd16d3eb Events : 72474 Number Major Minor RaidDevice State 6 8 3 0 active sync /dev/sda3 1 8 19 1 active sync /dev/sdb3 5 8 35 2 active sync /dev/sdc3 4 8 51 3 active sync /dev/sdd3 /dev/md/data-1: Version : 1.2 Creation Time : Wed Feb 21 04:51:56 2018 Raid Level : raid5 Array Size : 3906745856 (3725.76 GiB 4000.51 GB) Used Dev Size : 1953372928 (1862.88 GiB 2000.25 GB) Raid Devices : 3 Total Devices : 3 Persistence : Superblock is persistent Update Time : Sat Sep 5 08:02:38 2020 State : clean, resyncing (DELAYED) Active Devices : 3 Working Devices : 3 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Consistency Policy : unknown Name : 568aca8b:data-1 (local to host 568aca8b) UUID : 9e75db3f:24081c6f:d1515f20:e59052df Events : 130022 Number Major Minor RaidDevice State 4 8 4 0 active sync /dev/sda4 1 8 20 1 active sync /dev/sdb4 3 8 52 2 active sync /dev/sdd4 - PetrocAspirant
many thanks for the reply
cant remember the very original drive cobination but befr the most recent change i hink it was 4tb,3,2tb,3tb
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md126 : active raid5 sda4[4] sdd4[3] sdb4[1] 3906745856 blocks super 1.2 level 5, 64k chunk, algorithm 2 [3/3] [UUU] resync=DELAYED md127 : active raid5 sda3[6] sdd3[4] sdc3[5] sdb3[1] 2915738496 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU] [==================>..] resync = 90.5% (880496640/971912832) finish=46.4min speed=32810K/sec md1 : active raid10 sda2[0] sdd2[3] sdc2[2] sdb2[1] 1046528 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU] md0 : active raid1 sda1[6] sdd1[4] sdc1[5] sdb1[1] 4190208 blocks super 1.2 [4/4] [UUUU] unused devices: <none> /dev/md/0: Version : 1.2 Creation Time : Tue Feb 20 20:47:29 2018 Raid Level : raid1 Array Size : 4190208 (4.00 GiB 4.29 GB) Used Dev Size : 4190208 (4.00 GiB 4.29 GB) Raid Devices : 4 Total Devices : 4 Persistence : Superblock is persistent Update Time : Sat Sep 5 08:02:34 2020 State : clean Active Devices : 4 Working Devices : 4 Failed Devices : 0 Spare Devices : 0 Consistency Policy : unknown Name : 568aca8b:0 (local to host 568aca8b) UUID : 6ca489e0:ea2dfd6f:1330a41a:83693582 Events : 5723 Number Major Minor RaidDevice State 6 8 1 0 active sync /dev/sda1 1 8 17 1 active sync /dev/sdb1 5 8 33 2 active sync /dev/sdc1 4 8 49 3 active sync /dev/sdd1 /dev/md/1: Version : 1.2 Creation Time : Thu Sep 3 19:36:40 2020 Raid Level : raid10 Array Size : 1046528 (1022.00 MiB 1071.64 MB) Used Dev Size : 523264 (511.00 MiB 535.82 MB) Raid Devices : 4 Total Devices : 4 Persistence : Superblock is persistent Update Time : Sat Sep 5 07:54:47 2020 State : clean Active Devices : 4 Working Devices : 4 Failed Devices : 0 Spare Devices : 0 Layout : near=2 Chunk Size : 512K Consistency Policy : unknown Name : 568aca8b:1 (local to host 568aca8b) UUID : e083319b:882c0819:3d5e4ae3:d4d4c232 Events : 19 Number Major Minor RaidDevice State 0 8 2 0 active sync set-A /dev/sda2 1 8 18 1 active sync set-B /dev/sdb2 2 8 34 2 active sync set-A /dev/sdc2 3 8 50 3 active sync set-B /dev/sdd2 /dev/md/data-0: Version : 1.2 Creation Time : Tue Feb 20 20:48:03 2018 Raid Level : raid5 Array Size : 2915738496 (2780.66 GiB 2985.72 GB) Used Dev Size : 971912832 (926.89 GiB 995.24 GB) Raid Devices : 4 Total Devices : 4 Persistence : Superblock is persistent Update Time : Sat Sep 5 08:02:38 2020 State : clean, resyncing Active Devices : 4 Working Devices : 4 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Consistency Policy : unknown Resync Status : 90% complete Name : 568aca8b:data-0 (local to host 568aca8b) UUID : 55af480e:f05a8c92:bc26929e:bd16d3eb Events : 72474 Number Major Minor RaidDevice State 6 8 3 0 active sync /dev/sda3 1 8 19 1 active sync /dev/sdb3 5 8 35 2 active sync /dev/sdc3 4 8 51 3 active sync /dev/sdd3 /dev/md/data-1: Version : 1.2 Creation Time : Wed Feb 21 04:51:56 2018 Raid Level : raid5 Array Size : 3906745856 (3725.76 GiB 4000.51 GB) Used Dev Size : 1953372928 (1862.88 GiB 2000.25 GB) Raid Devices : 3 Total Devices : 3 Persistence : Superblock is persistent Update Time : Sat Sep 5 08:02:38 2020 State : clean, resyncing (DELAYED) Active Devices : 3 Working Devices : 3 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Consistency Policy : unknown Name : 568aca8b:data-1 (local to host 568aca8b) UUID : 9e75db3f:24081c6f:d1515f20:e59052df Events : 130022 Number Major Minor RaidDevice State 4 8 4 0 active sync /dev/sda4 1 8 20 1 active sync /dev/sdb4 3 8 52 2 active sync /dev/sdd4- StephenBGuru - Experienced User
Did you just replace the disk? If so, you just needed to wait longer (likely it is already expanding by now).
Also, what disk models do you have?
This is the original RAID group, which is still resyncing (which looks like you just replaced a disk).
md127 : active raid5 sda3[6] sdd3[4] sdc3[5] sdb3[1] 2915738496 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU] [==================>..] resync = 90.5% (880496640/971912832) finish=46.4min speed=32810K/secAfter this completes, the expansion step will begin.
