yusahtr33's avatar
yusahtr33
DLNA disconnect
While I'm streaming a video to my TV through DLNA my readynas 104 will disconnect randomly. I have the latest firmware. 6.5.1. Anyone else having issues like this?
  • BrianL2's avatar
    BrianL2
    NETGEAR Employee Retired
    Hi yusahtr33,
    Welcome to the community!
    Does the same behavior show when you access your files locally on your PCs or other DLNA enabled devices? Could you also send in your logs so we can check your system?
    Kind regards,
    BrianL
    NETGEAR Community Team
  • JennC's avatar
    JennC
    Hi yusahtr33,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
    The Netgear community looks forward to hearing from you and being a helpful resource in the future!
  • No the behavior is only on my TV. When I stream on my computer it works fine.
    • BrianL2's avatar
      BrianL2
      Hi yusahtr33,
      What was the brand of your TV and how does it connect to your network (LAN or WLAN)?
      Kind regards,
      BrianL
      • yusahtr33's avatar
        yusahtr33
        it's a mitsubishi 5570 and i use WLAN to connect via DLNA
ProSupport for Business
