stebo85
May 23, 2016Tutor
SSH and SMB service not starting anymore
Dear community,
After installing the add-on Log-Analyzer my RN10200 started to have some issues as I was not able to see the shares via Samba anymore. I tried logging in via SSH to see what's wrong but also SSH stopped working. Since the web-admin panel is still working I tried to activate SMB and SSH in the panel, but it briefly turns green and then grey again. I also tried uninstalling the add-on, but now get a package manager error. I then tried to reinstall the OS using the boot-option, but this did not help either.
I removed the harddrives from the device and mounted them read-only to see what's wrong. There I found some permissions to be set incorrectly on the system partition:
 /mnt/systemOld# ls -la
total 124
drwxr-xr-x 26 root root 4096 May 19 21:03 .
drwxr-xr-x 4 root root 4096 May 24 07:04 ..
drwxr-xr-x 2 root root 4096 May 5 2015 apps
drwxr-xr-x 2 root root 4096 May 19 19:51 bin
drwxr-xr-x 2 root root 4096 Jun 17 2012 boot
drwxrwxrwt 2 root root 4096 May 5 2015 data
drwxr-xr-x 4 root root 4096 May 19 19:51 dev
drwxr-xr-x 79 root root 4096 May 19 21:32 etc
drwxr-xr-x 6 guest guest 4096 May 19 19:51 frontview
drwxr-xr-x 2 root root 4096 Jun 17 2012 home
lrwxrwxrwx 1 guest guest 5 Jul 18 2015 homes -> /home
drwxr-xr-x 14 guest guest 4096 May 19 19:51 lib
drwxrwxrwx 2 guest guest 16384 May 5 2015 lost+found
drwxr-xr-x 2 root root 4096 Nov 18 2012 media
drwxr-xr-x 3 root root 4096 Jun 17 2012 mnt
drwxr-xr-x 9 root root 4096 Nov 26 10:59 opt
drwxr-xr-x 2 root root 4096 Jun 17 2012 proc
-rwxrwxrwx 1 guest guest 1024 May 5 2015 .rnd
drwx------ 5 root root 4096 May 19 19:51 root
drwxr-xr-x 3 guest guest 4096 May 19 17:52 rsyslog
drwxr-xr-x 2 root root 4096 Aug 18 2015 run
drwxr-xr-x 2 guest guest 4096 May 19 19:51 sbin
drwxr-xr-x 2 root root 4096 Jun 10 2012 selinux
drwxr-xr-x 2 guest guest 4096 Nov 18 2012 srv
drwxr-xr-x 2 root root 4096 Feb 8 2013 sys
drwxrwxrwt 7 guest guest 4096 May 19 21:32 tmp
-rwxrwxrwx 1 guest guest 33 May 19 17:48 .update_fail
drwxr-xr-x 10 root root 4096 Nov 26 10:59 usr
drwxr-xr-x 18 root root 4096 May 19 19:51 var
instead of:
ls -la /
total 120
drwxr-xr-x 26 root root 4096 May 23 07:40 .
drwxr-xr-x 26 root root 4096 May 23 07:40 ..
drwxrwxrwx 1 root root 116 May 23 20:45 apps
drwxr-xr-x 2 root root 4096 May 23 07:39 bin
drwxr-xr-x 1 root root 250 May 22 10:36 data
drwxr-xr-x 13 root root 3480 May 23 20:53 dev
drwxr-xr-x 79 root root 4096 May 23 20:46 etc
drwxr-xr-x 6 root root 4096 May 23 07:39 frontview
drwxr-xr-x 1 admin admin 0 May 19 22:17 home
drwxr-xr-x 14 root root 4096 May 23 07:39 lib
drwx------ 2 root root 16384 May 19 22:17 lost+found
drwxr-xr-x 2 root root 4096 May 19 22:49 md124
drwxr-xr-x 4 root root 80 May 23 20:53 media
drwxr-xr-x 4 root root 4096 May 24 07:04 mnt
drwxr-xr-x 9 root root 4096 May 13 16:48 opt
dr-xr-xr-x 188 root root 0 Jan 1 1970 proc
-rw------- 1 root root 1024 May 19 22:17 .rnd
drwx------ 3 root root 4096 May 23 07:39 root
drwxrwxr-x 26 root admin 820 May 23 20:53 run
drwxr-xr-x 2 root root 4096 May 23 07:39 sbin
drwxr-xr-x 2 root root 4096 Nov 18 2012 srv
dr-xr-xr-x 11 root root 0 May 24 07:05 sys
drwxrwxrwt 7 root root 4096 May 24 07:17 tmp
-rw-r--r-- 1 root root 0 May 23 07:38 .update_success
drwxr-xr-x 10 root root 4096 May 13 16:48 usr
drwxr-xr-x 17 root root 4096 May 23 07:39 var
could this be cause of the problem? Any other ideas how I get the SSH and SMB service back working or get more diagnostic information?
I do have a backup of everything so a full factory reset would be an option. However, I would like to understand the problem and rather solve it using telnet as it seems to be quite a simple problem? Would it be enough to reset the permissions? What else could cause this behaviour?
Thanks for any hints
Best
Steffen
- You would have to go folder by folder and read all the folders it is complaining about and chown the permissions back to root instead of guest. It's tedius but eventually you can get it all started again.
- mdgm-ntgrNETGEAR Employee RetiredHow full is the OS partition? Another possibility could be filling that. It's 4GB so if you put stuff on there that shouldn't be there it can fill fast.
- kohdeeNETGEAR ExpertYou would have to go folder by folder and read all the folders it is complaining about and chown the permissions back to root instead of guest. It's tedius but eventually you can get it all started again. - stebo85TutorThank you, I could log in via telnet and change back the ownership to root and chmod the /etc/ssh/ssh_host* files to 600. This fixed it :) Much quicker than factory reset. Thank you for the help Cheers Steffen - stebo85TutorJust for completeness and in case someone else has the same problem: Resetting the permissions was easy thanks to this great script: https://gist.github.com/paalfe/c4c87be63c7519d1dbe8 After rebooting the readynas from the telnet service mode you have to be quick to login via SSH, because unfortunately the permissions are getting reset to guest after a few minutes. The reason is that loganalyzerr6 is still trying to install itself and during that install it changes all permissions. I tried to purge it using apt-get -y purge loganalyzerr6, but this did not work because dpkg was already running in the background and was stuck in the install loganalyzerr6. However, it worked to kill dpgk and then run dpkg --purge loganalyzerr6. Then I reset the permissions again and now it works. Best Steffen
