pierrexp's avatar
Jul 19, 2013
SMART
Bonjour à tous,
j'ai un log smart bizare, les deux disques tombent en panne en meme temps?
Voici le log:
***** Disk SMART log from 2013/06/09 *****
***** Disk SMART log for channel 1 [sda] *****
smartctl 5.42 2011-10-20 r3458 [x86_64-linux-2.6.37.6.RNx86_64.2.4] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: Seagate Barracuda Green (Adv. Format)
Device Model: ST2000DL003-9VT166
Serial Number: 5YD99R85
LU WWN Device Id: 5 000c50 049c6ea6c
Firmware Version: CC45
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Sun Jun 9 09:06:04 2013 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 623) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x30b7) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 105 099 006 Pre-fail Always - 47680
3 Spin_Up_Time 0x0003 094 092 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 096 096 020 Old_age Always - 4820
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 066 060 030 Pre-fail Always - 12898840566
9 Power_On_Hours 0x0032 098 097 000 Old_age Always - 2188
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 101
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 076 055 045 Old_age Always - 24 (Min/Max 24/24)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 34
193 Load_Cycle_Count 0x0032 098 098 000 Old_age Always - 4821
194 Temperature_Celsius 0x0022 024 045 000 Old_age Always - 24 (0 21 0 0 0)
195 Hardware_ECC_Recovered 0x001a 014 003 000 Old_age Always - 47680
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 47373489276901
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 3119000620
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 4088383019
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 1 -
# 2 Short offline Completed without error 00% 0 -
# 3 Short offline Completed without error 00% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
***** Disk SMART log for channel 2 [sdb] *****
Serial Number: 5YD95REC
LU WWN Device Id: 5 000c50 049be20cf
ATA Version is: 8
Local Time is: Sun Jun 9 09:06:10 2013 CEST
been run.
data collection: ( 612) seconds.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x000f 117 099 006 Pre-fail Always - 710648
3 Spin_Up_Time 0x0003 093 092 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 096 096 020 Old_age Always - 4824
7 Seek_Error_Rate 0x000f 071 060 030 Pre-fail Always - 4309147509
9 Power_On_Hours 0x0032 096 095 000 Old_age Always - 4090
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 96
190 Airflow_Temperature_Cel 0x0022 076 057 045 Old_age Always - 24 (Min/Max 23/24)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 28
193 Load_Cycle_Count 0x0032 098 098 000 Old_age Always - 4824
194 Temperature_Celsius 0x0022 024 043 000 Old_age Always - 24 (0 20 0 0 0)
195 Hardware_ECC_Recovered 0x001a 021 003 000 Old_age Always - 710648
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 273086905583590
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1584279076
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 2800739496
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Merci d'avance de votre aide.
Pierre
No RepliesBe the first to reply
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
ProSupport for Business
