× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
A6100 Blue Screen SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
crispin
Novice
Hi - Hope you can help!
OS Win 8.1
A6100 Software Version 1.0.0.17
Installed the software, plugged in the adapter at the software prompt, then the system bluescreens immediately:
Address A6100.sys+168e6f
Bug Check String SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Bug Check Code 0x1000007e
Parameter 1 ffffffff`c0000005
Parameter 2 00000000`00000000
Parameter 3 ffffd001`4cdace28
Parameter 4 ffffd001`4cdac630
Message 1 of 2
Buckinghamshire
Re: A6100 Blue Screen SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
As fast as possible after boot go to device manager and uninstall the driver. Then install the driver via the installation disc that came with it.
Now connect to the Internet but not via the Genie, but the normal windows way. This worked for me when I got your problem.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 16661 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
