Purge_Camo
May 29, 2019Follower
A7000 recent random disconnect.
Recently my Adapter for my pc has been random disconnecting from the wifi without blinking the blue light like it usually would if it cant find the wifi. so the past few days it has randomly been disconnecting from the wifi and it takes its sweet time of slowing down before i lose connection.
It has only been the adapter disconnecting because all teh devices in the house are perfectly fine. I have the lastest firmware, power management is off. Could someone please suggest a fix because it has been getting pretty annoying.
I am not 100% sure if this is the right adapter model, i am just going by A7000 because of the netgear app on my desktop.
- tommy_bAspirant
I'm having a similar (if not the exact same) issue. I bought the adapter a week ago and it worked perfectly fine for the first 5 days. A couple days ago the adapter randomly switching between a full strength connection similar to what it used to be like and a completely empty strength connection that is unusable. I agree it is extremely frustrating as it interupts the flow of any computer activity involving the internet.
