jonilo5
Oct 27, 2015Aspirant
BSOD issue Win 8.1 64 bit WNA3100
I get alot of BSOD, and I suppect it can be my WNA3100, but I have Windows 8.1.
- jonilo5Aspirant
I am not sure, but sometimes when I get BSOD the WNA3100 has a constant light (blue) - even when the computer is off. To fix it I have to remove it from the USB and but it in an other Usb-port.
Not sure what this will tell (the lastest BSOD I got) :
This was probably caused by the following module: scmndisp.sys (scmndisp+0x16D1)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\scmndisp.sys
product: ® Neutral Wireless Solution
company: Windows (R) Codename Longhorn DDK provider
description: NDIS User mode I/O Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: scmndisp.sys (NDIS User mode I/O Driver, Windows (R) Codename Longhorn DDK provider).
Google query: Windows (R) Codename Longhorn DDK provider IRQL_NOT_LESS_OR_EQUAL
"Thanks for the reply! :)
- jonilo5Aspirant
Is there any update, beta or patch to the driver?
I think it is this driver making BSOD. (WNA3100_V2.2.0.2)
