Tj2's avatar
Tj2
Wireless adapter loses connection
Hello,
Recently put a PC together and was looking into wireless networking soloutions. I purchased this adapter and plugged in to a USB3.0 port. The adapter randomly disconnects from the internet and I can either run the windows troubleshooter and it will reset the adapter, or I can remove it from the port for a few mments and then reconnect it.
So far I have done some reasearch and preformed the following steps.
1. I installed the proper driver with the NETGEAR Genie application.
2. I stopped and disabled the NETGEAR port service. I found that others have had some sucess with this step reportedly because the adapter switches from USB2.0 to 3.0 often.
3. I instaalled in a USB 2.0 port and have still had the same problems.
4. I have changed power settings where possible to prevent the USB selective suspend action. Networking adapters are set to maximum preformance.
I am attempting to connect to my 5GHz home WIFI network (I have a 2.4GHz channel to use if required but I purchased this product for the speed offered by my ISP and connected home).
My configuration is as follows:
Socket AM4 motherboard X570 chipset.
Windows 10 64bit installed and updated current.
My local store did not have a large selection of PCI add in cards which may be more reliable. I want to see if I can find a soloution with this device before I decide to try another hardware option.
Thank you,
Tim
    • Tj2's avatar
      Tj2
      I am afraid that after some other changes, nothing helped. I literally went thrugh every option even if it did not make sense and I still had the conneciton issue. I ended up moving things around in the room and running CAT6 to the onboard LAN adapter and problem solved. I took the wireless adapter back for a refund. I usually have good luck with netgear products but this one just was not working.
