DrJosh
May 20, 2020Aspirant
1 of 4 apple products will not connect to internet through extender
I have had this extender for several years and have had no problems until recently. We have 2 iPhones (both 11s), an iMac and MacAir. All but 1 of the iPhones connects to the internet through the extender using either the 2GHz or 5GHz network without difficutly. The remaining iPhone will connect to the extender but gets no internet connection. The phone can connect wirelessly without difficulty using the modem. I have tried resetting the extender. I have tried 'forgetting' both networks and reinstalling them on the phone. Nothing has worked. I reviewed previous discussions and found that this is not a unique problem but no one appears to have found an answer yet. Any suggestions?
For unknow reasons, before I had a chance to re-install the extender and after 3 days of no internet connection on my phone from the extender, the problem spontaneously corrected itself. I am posting this for future reference. If the problem occurs again, I will re-install the extender using the Wizard. Thank you.
what router are you connecting it to?
What extender are you using?
Firmware on the extender?
did you set it up via wps or the installation wizard?
- DrJoshAspirant
Our carrier is xfinity.
Router is Arris Model TG1682G
Extender is Netgear EX6200
To the best of my knowledge, no firmwar on the extender
I set it up via WPS are I reset the extender to its initial settings
i would try re-installing the extender by using the installation wizard and not via wps.
