bili's avatar
bili
Follower
Apr 09, 2022
3 years old EX2700 setup
I have a 3 years old EX2700 extender. I replaced my router and now unable to setup my extender. How can i connect it to my new router without WPS. I still have my login access to www.netgear.com.
1 Reply
  • plemans's avatar
    You can set it up using the installation assistant.
    Factory resets it (push and hold reset for 7-15 seconds while powered on) and then install it using the assistant.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
