MIKEFROMSA
Jan 17, 2019Follower
AC1200 Wifi extender EX6110
I have 4 devices connected to the router. TV, Samsung smartphone, I-pad, and laptop and all in close range of each other, The TV and I-pad find 5 Ghz, but the smartphone and laptop only find 2 Ghz, Is there any way they can all find 5 Ghz?
1 Reply
- Christian_RNETGEAR Employee Retired
Hello MIKEFROMUSA - The clients that are connected to the extender will connect to the best band suitable. You may disable the extender's 2.4Ghz by logging into the extender's user interface to see if your smart phone and laptop connect to the 5Ghz band.
~Christian
