Flgal7's avatar
Flgal7
Initiate
Dec 08, 2020
AX1800 4-Stream WiFi Mesh Extender-EAX20
I purchased my unit on Friday December 4/2020 and received it in yesterday's mail. The box did not contain a quick start guide or the power adaptor. I am looking for access to optaining the missing power adaptor so I can use the range extender. I have contacted support and have a case number but keep getting hung up on. Can someone point me to the missing power supply adaptor, please?
  • This is the community support forum. Where members of the public try to help out.
    Your best options?
    1. support (which you've done)
    2. return/exchange it from where you got it.
    the install guide can be found at the support site. go to netgear.com/support/   type in your model number and it takes you to guides, firmware, and manuals.
  • plemans's avatar
    Your best options?
    • Flgal7's avatar
      Flgal7
      Initiate
      Thank you. I tried both your solutions. The reason I came to Netgear for assistance is I was hoping they had a parts department. I am returning the first one to Amazon where I purchased it. Yesterday I purchased the same model directly from Netgear and go from there.
      • plemans's avatar
        They don't. Sadly most replacement power supplies come from amazon/ebay
