- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AX1800 Firmware upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I am a bit confused about the firmware upgrade of my device.
For the APP the firmware is ok and the versione is 1.0.0.52. Instead if I use the web interface from a PC, the system indicates a new version (1.0.0.58_1.0.101). If I try to update the firmware from the web the device results blocked and I am forced to reset it.
Where am I wrong?
Thanks
R
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AX1800 Firmware upgrade
You have the MK system?
If so , the latest firmware is even newer.
try a manual firmware upgrade process.
https://www.netgear.com/support/product/mk62.aspx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I don't have a MK system at the moment.
I will try the manual firmware update procedure.
Thanks
R
- Mark as New
- Bookmark
- Subscribe
- Permalink
What system do you have? AX1800 is a speed, not a model
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry, the model is EAX20 (AX1800 4-Stream Mesh Extender).
The manual update works, I uploaded the last firmware version.
Thanks
R
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it updated. Let us know if you have other issues
