SwedenGothic
Jun 23, 2019Aspirant
Ac750 Does not accept password
The device will not accept the password. Everything else seems fine, all relevant lights are shining.
No i can't use web sign in since the device doesn not display netgear_ext network used for manual set-up. (WPS has been used and both bands are active, neither accepts the password.)
I have also tried factory reset.
- Christian_RNETGEAR Employee Retired
Hello SwedenGothic - Would you mind telling us what password you're referring to such as the WiFi password or admin page password?
~Christian- SwedenGothicAspirant
It is the wifi password.
Hello SwedenGothic - Thanks for getting back. May you try holding down on the factory reset button for 15+ seconds. After doing so, the extender should factory reset and you will be able to go through the setup instructions again.
~Christian
