RollTide69's avatar
RollTide69
Follower
Jun 09, 2018
Can't connect Netgear AC750 range extender to Netgear N300 router. No WPS button on router.
I Can't connect Netgear AC750 range extender to Netgear N300 router. There is no WPS button on router and instructions say to push that button.
1 Reply
  • You didn't specify the model of your Netgear router. N300 is a speed class. In any case, many Netgear routers have a "soft" WPS button that is available on one of their setup screens.
    Alternatively, you can log into the range extender and manually enter the SSID and Wi-Fi password from your router. Consult the manual for the extender for instructions.
