MB100
May 15, 2020Tutor
Cannot connect to http:// www. mywifiext. net/
Hi Hope someone can help, I am definately connected to my range extender but keep getting the error message saying I am not or cannot connect. Actual message says "You are not connected to your extender's WiFi network.". I want to chaneg soem settings in my extender but can't login - any ideas please? I don't have support with netgear as extender is too old. Thanks, Mike
If you log into whichever router you have, you should be able to find the attached devices page (or equivalent). Find the ip address for the extender and use that to connect to it.
