Xrgear
Jun 05, 2018Aspirant
Cant connect wifi camera
I have a ex7000 wifi extender i can connect to the laptop , smartphone , smart tv without issues
But i cant connect to the wifi camera what would be the issue here?
- DarrenMSr. NETGEAR Moderator
Does the extender have the exact same wireless name as your main router? if so you may try changing the SSID on the extender then try connecting those devices.
DarrenM
- XrgearAspirant
hi sorry for late reply i worked out that the password doesnt like special characters so it seems i need to confirm this again
also in the settings i changed it static ip
then restarted everything
now the cam is connecting
