- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Changing EX 7000 SSIS paswords
- Mark as New
- Bookmark
- Subscribe
- Permalink
I forgot one the two passowrds for my dual band EX 7000 range extender. How can I easily reset the PW for the bandI have forgotten the PW?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Changing EX 7000 SSIS paswords
login to the extender through the working ssid (the one you know). Once logged into the extender, you can change ssid's and passwords.
mywifiext.net
Or you can log in via a hardwired device. this bypasses needing the ssid password. You just need to know your gui login info
- Mark as New
- Bookmark
- Subscribe
- Permalink
and how do I find my GUI login details?
- Mark as New
- Bookmark
- Subscribe
- Permalink
hopefully you remember them.
The defaults are:
login: admin
password: password
if you changed them and don't remember them, the only way back in is to factory reset it and start back from fresh. To do that, push the reset button (while powered on) for 7-10 seconds, until the lights change.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure how to get to the GUI.
- Mark as New
- Bookmark
- Subscribe
- Permalink
either connect to the extenders wifi or hardwire into it. type mywifiext.net into the address bar
