Proxydraw's avatar
Proxydraw
Follower
Nov 24, 2016
Changing wifi extender IP
 For some time my family and I have been using a terrible wifi, and we finally upgraded to using a more serious setup. One of the devices is as recommended, also one of the wifis that has everyone connected. With all the dos attacks happening lately, it's hard to use the internet right when I want to. Is there any way to change the IP of the extender? (didn't change the wifi names so you already know it's "ext and 5gext")
Been looking on youtube on how to change my DYNAMIC IP, but that doesn't change the wifi extender's IP, unless of course I'm thinking of the whole situation incorrectly.
Situation:
New wifi
New router, new modem, new wifi range extender
wifi extender EX7000 is getting dossed
Use MAC primarely
  • I could have misunderstood you, but your thinking is off.  A Wi-Fi extender is internal to your network and cannot be directly DoS attacked from the Internet, so you don't need to worry about changing its IP address.
    If you are getting attacked, it would be your router that would be taking the brunt of the attack.  What you probably read about is changing the public IP address on the router's Internet port.  This can sometimes but not always stop a DoS attack.  If someone has a personal vendetta they are probably finding you through some other means.  For example, maybe you pissed off someone in an online game.  They will probably figure out your new IP address while you are playing the game.
    Whether or not you can change your public IP address depends on your Internet service and setup.  If you have a combination modem/router, then there's nothing you can do to change the IP address; you can try begging with your ISP to change it on their end but good luck.
    If your router is separate from your modem, then a common technique is to change the router's MAC address.  This will often result in getting a new IP address.
1 Reply
