× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
DHCP server WNAP210
ensign_ricky
DHCP server WNAP210
Can I use the WNAP210 as a DHCP server? The manual seems to imply I can, but I don't see the option anywhere in the configuration settings.
Thanks.
Message 1 of 4
mendalon
Re: DHCP server WNAP210
G'day,
I had the same issue. I tried upgrading the firmware but still no options appeared in the web interface relating to DHCP server functionality. I also tried the listed commands in Appendix C during a terminal session but the the device didn't recognise the 'dhcp' command.
After getting in contact with Netgear support (a very tedious process) they confirmed that the documentation is incorrect regarding the WNAP210. Apparently the DHCP server functionality applies to a different, related model. It think it's simply a case of Netgear not updating the documentation between models.
I think the device will relay DHCP requests to another DHCP server on your LAN by default. At least that's what mine does.
Message 2 of 4
ensign_ricky
Cheers, Thanks for clearing it up.
yep it is relaying the DHCP requests.
Message 3 of 4
jmizoguchi
Virtuoso
most your Access point are not design to do DHCP server ..
WGXX series with hotpot capable can provide DHCP
http://interface.netgear-forum.com/WG302v2/
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 5634 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
