Reply
EAX20 AX1800 how can I change the security type
pubpurc
When my iPhone 12 Pro is connected to the extender, the phone tells me that the connection has a weak security. I tried to find out the security type ie. WPA, WPA2 or WPA3 on the extender. The Wireless section of the extender GUI shows only that the connection is protected but it does not tell me which security type it is using. How can I change the security type for the bands?
Message 1 of 3
Guru
Re: EAX20 AX1800 how can I change the security type
If you set it up using wps, it uses the same security of your router.
You can factory reset and extender and reinstall it using the installation assistant if you'd like.
Check the security on your router as well.
EAX20 | WiFi Range Extender | NETGEAR Support
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 3
pubpurc
Thanks for the suggestion. In fact the security type can be set manually when I create a new password for the bands instead of using the same passwords as the router.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 174 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
